I've just taken the rear wheel off my '83 GL1100I to replace a thin brake disk. While I have it off I will be changing the bearings also and inspecting the final drive gears.
When I took out the axle to remove the wheel, two little spacers fell out of the left side. Now, I don't know exactly how to replace them. They must go one each side of the brake caliper bracket, but they are different from each other and each has a shoulder, so it matters which way round they go.
Can anyone help me here?
Thanks,
Gilbert
I know what you mean. It's a puzzle. use the dirt marking on the spacers as a clue when putting it back together. Where the spacer is recessed it will be cleaner.
I had to do some trial and error once.
Older and Wiser
The one with the shoulder fits nearest the wheel, narrow end actually fitting into the seal. Can't remember the other one.
