1 - 3 of 3 Posts
See other thread on less-than-perfect gas mileage :shock:..
Should I plan on trying to rebuild this with the requisiteO-rings, etc.or is there some sort of diaphragm in the middle of the contraption that must be factory fresh?
You can order an aftermarket rebuild kit, through your honda dealer -- the main diaphragm, o-rings and spring. There is an o-ring on the top part, and when you take the valve off the carb body, two underneath. Mine cost about $30 Cdn or so.
1 - 3 of 3 Posts
