I put new progressive springs in my front forks last year. The bushings were showing a lot of wear and need to be replaced. Does any one make a rebuild kit with all the parts, (seals clips bushings)?
no has put together a re-bush kit for any forks that i know of. would not be a bad idea though.
Drag specialties make a 39mm kit. But I dont know if all the parts will fit my GL1100. It has Showa forks, so they may be standard. I just don't know. I am trying to find enough information on them. There also complete fork kits with new tube and seal, again I don't know it they are the same
Robert
C O M O Z E
DBI 24-1/4" (Stock Length) 39mm Fork Tube Assembly With Easy Fill Top Caps
0658-0100
S pecification:
DBI 24-1/4" (STOCK LENGTH) 39MM FORK TUBE ASSEMBLY WITH EASY FILL TOP CAPS
Includes all internal parts. Hard chrome finish like OEM. Damper exposed 4-7/8" from the bottom of the tube. Tube exposed 15-3/4" from top of lower leg to top of fork tube (excluding fork tube top cap)
Anybody know if these will fit my 1981 GL1100 with Showa forks
Itinerant Wing Preacher
The bushings are available from Honda.
