Hello All,
been reading posts off and on for the last few yrs. Decided to join, so I can post esp. in the post about thread lock for rotor bolts. Honda's color coding has zero correlation with Lock-tite.
I have a '98 Valkyrie standard converted to a Tourer model. I have done many modifications the over the years. Interstate (I/S) model seven gallon fuel tank and after market Viking exhaust system are just a few things. I have modified the air box and re-jetted. last dyno run was 116HP and 106 ftlbs.
Presently installing a set of heads I had ported and flowed tested, with a set of non-emissions camshafts.
Also replaced the triple clamps with a set from an I/S which will provide better handling.
I most likely will hang out in the tech forums.
Thanks for letting me join.
Hallo ValkyrieRider
And good luck with your Wing.
