What is the recommended pressure for the front suspense?
Opps forgot, on a 2000 1500SE
If you look inside the left front door on the B pillar, it should have a label with the tire and suspension pressures.
I remember that asked here before and I think the Honda figure is 6psi, but many run up to 12 or 14psi with no problems.
Lost on this *****
I was always told no more then 6lbs. Any more could blow out the seals. I generally ran with 4lbs till I changed to Progressive Springs,,,, now I don't need to add air :).
Also,,,,,,, when adding air to the forks,,,,,,, you need to use a source of LOW pressure, so as not to over pressirize. I always used a portable air tank with no more then 10lbs pressure in it.And then it only took a "quick spert" to bring the forks up a little over 6lbs.Then I would release the air till I got 4lbs.
Thanks for the information.
Thanks, just purchased one SidecarMike.
