Has anyone heard of using a buss box to reduce electrical load on a '83 intetstate? This is something i would be interested in trying. Mother Honda was not very kind by providing only one accessory terminal! Rated at just 5 amps. I have a full compliment of lights on my '83 interstate. The problem is that i cannot operate my lower running lights (add on by previous owner and never connected) without blowing fuses. i am left with head and tail light only, after that...:baffled: i want to take power from mostly the battery and not the fuse buss under the tank housing (false tank) by installing a seperate fuse buss under the left side cover. And put the running lights under the fairing on thier own circuit. and the bumper lights on thier own as well. Hopefully? just let the stator maintain the battery, head light and tail/brake light... taking power from the battery to opreate the other lights... (direct from battery to new fuse buss) I have heard that relays should be used for this kind of set up. But have no clue as to what type of relay or relays i should use.??... One thing i did was to install a sunpro voltage gauge on my wing. just above the right glove box. that is running off the accesory fuse buss. Just not enough amps to run all this bike has off just one weak terminal.! this i know... can any one help with this?...... i think i'm on the right track with the add on fuse buss. and i will be using 14ga. wire for the change over.. Plus i will have 4 spare terminals with this new fuse buss. found this at napa auto parts. is only one in. in height and i think no more tha 3 in. in width. should fit nicely under the side cover. Attaching to the battery holding bar... using cable ties..so it can fold down out of the way. Should i everneed a new battery?..... just need some advice about this change over... any help with this is greatly appreciated...:headbanger:
