1 - 9 of 9 Posts
I'm a little confused about the relays on the left side of the bike backwards of the fuses. All but one seem to have the same part number. The odd one is also blue and the others black. Is this the famous #3 relay? And what does it control?
What position is the blue relay in? The one on the top right is #3. Could be one has been replaced with the blue one, they all are the same originally.
As you can see in the diagram relay #3 is in the upper right of the fuse block.
[/IMG]
Thanks for the replies. It's actually on Nyme's bike and we noticed it while doing the repair in the thread below. He's away now so I can't get a picture but it was in the second row down on the right. It definitely had a different number on it's case from the black ones. Probably was a replacement - I hadn't thought of that.
I only asked as he was planning to buy some new ones as he read somewhere on this site it's good to change them as the bike gets older.
http://www.goldwingfacts.com/forums...-us-spec-wont-attempt-turn-starter-start.html
Some of the relays are identical parts. Post a picture of your relays, it will help us ID them.
The plot thickens!! I've just rooted out my Haynes manual which does mention a blue relay. I've scanned the page and attached it here but I still don't really know why one needs to be different from the rest. You can see the blue one in picture 5.1b. It also mentions it is a different fitting to the others. Anyway, not terribly important but needed to know to order a spare.
Note that if you're replacing the relays, you can simply make them all the Same... for example, I've changed all of mine to 30amp Pilot Relays (even the ones that were formerly 20 amp).
Realize that relays are Not like fuses (which require idenical amperage replacements)... You can safely up the amperage on a relay to whatever amount you like, without risk of harming the electric system.
Discussion Starter · #9 ·
Thanks for that tip. That's good to know as I expect ones from Honda are expensive
1 - 9 of 9 Posts
