Has anyone been successful in removing the carbs on a 1986 GL1200I?
The come out the same way as on the other GL1200 model years. What problem are you having? They should come out to the left of the bike.
Having just done it I can say it can be done but you may learn a few new words. :X
You did remove the lower "tubes" to each carb right? Then is it a matter of sliding the carbs to the left just enough to get the trottle cables and choke cable off. Pull that vacuum line off of the No. 4 carb. The as you rotate the carb rack counter clockwise slightly also lift up a little on the front of the the carb rack. It is a tight fit but once you learn the technique it is very easy.
Remember as you move the carb body to the left, lift the front of the carb rack and rotate it slightly counter clockwise.
If you want to gain confidence BEFORE you take them out/apart, get the Randakk's carb manual, which gives you step-by-step color pictures/instructions on how to do it. I have his manual and my bike has his carb kit. I highly recommend it. Also don't forget to sinc/set idle,etc. when you're done, she'll run smooth.
1987 GL1200 Interstate
Whutcha doin' to the carbs? I've had mine out a few times. Twice this week, as a matter of fact.
How far along are you, and, do you have the Honda service manual?
