Just wondering how hard it is to remove the gl1500 emblems off side covers? Bought new covers without emblems. And bought old beat up cover with emblems off EBay to put on new cover. How did Honda attach emblems to oem?
Yeah, you sure don't want a warped hair dryer! :ROFL::ROFL::ROFL:carefull not to let the hair dryer sit in one spot to long or it could warp.
+1 on the WD40 :claps:I took the emblems off my VTX by squirting a little WD 40 on em, let em soak and use doubled up dental floss in a sawing motion...cleaned up with goo gone...the floss is more forgiving than fishing line...good luck
Aww C'mon now... There's no need to be defensive about the dental floss remark! After all, it's well known that the Tooth Brush was invented in the great state of Georgia!!!:coollep:Thanks for all the replies. Think I will try the wd40 first. My only problem with that method where in Oklahoma do you expect me to find dental floss? ( I'm from Okla anyone else said that it would be on.![]()
Last year during a group ride up to Mt Rainier my wife broke the G off of the Goldwing emblem on the right side cover of the 1800. She started to get off the bike and stumbled, her boot caught the G and ripped it right off.
I thought about just leaving it as an "Oldwing" until I checked on the price of the Emblem. It was $27.00 plus tax. WHAT!!! A Honda Goldwing part for $27.00!!!, yep and you can even get them for as little at $17.00 plus shipping online!!.
So here is the sequence of events and pictures....I know how you all like pictures!!
Here is the damaged part:
I borrowed the wife's hair dryer and floss (don't tell her!!!!!!!!!!!).
The Hair dryer to loosen up the doublestick glue.
And then next I used the floss to cut it away.
The Emblem has tabs that stick through the side cover aligning it to where Honda wanted it. This makes cutting through the glue difficult. You will have to pry up the end you have already separated and insert the floss after the tab to continue cutting the glue loose.
The removed emblem showing the tabs and the holes in the side cover where they go through. The glue is a sticky mess at this point and does not readily peel off.
To remove the glue soak some cotton pads (get them from the wifes makeup drawer), cut them in half, soak them in Mineral Spirits and apply to the glue for 15-20 minutes. The Mineral Spirits does not hurt the paint or clear coat!!.
Scrub the glue away with a dry cotton towel or wash cloth. The glue will still be somewhat tacky but will come off with a bit of rubbing. Below you see the side cover with all of the glue removed and the scratches from her boot still present.
Next you will need to remove the scratches and residual crap from the glue and wax buildup around the Emblem. You can use whatever brand of scratch and swirl remover you want. I used NicSand 10,000 because I had it already. It is a water based Aluminum Oxide 10,000 grit sanding Gel. Below the side cover has the scratches removed and is ready for the new Emblem.
And now remove the plastic backing and stick down the new emblem. Put your hand behind the cover to hold it up while you use a cloth from the front to push down on the emblem to firmly seat it against the side cover. Final Product is below, ready for the first coat of polish.!!!
Total time from start to finish was about 45 minutes. Not including the time it took to distract the wife while I raided her makeup supplies.!!!! (of course she did the damage so I might be able to use that as a negotiating tactic if she finds out):ROFL:
Henry
