imported post any one know what size hex I need to remove seat from a GL1100? thanks Terp
T terp · Premium Member Joined Jul 5, 2009 · 50 Posts Discussion Starter • #1 • Aug 24, 2009 imported post any one know what size hex I need to remove seat from a GL1100? thanks Terp
A Anon · Premium Member Joined Jul 2, 2009 · 75 Posts #2 • Aug 24, 2009 imported post I know it's kind of a wise-guy answer, but just grab your set of metric allens, and try until one fits. If you're working on a gw, you should have a decent set.
T terp · Premium Member Joined Jul 5, 2009 · 50 Posts Discussion Starter • #3 • Aug 24, 2009 imported post I'll just have to buy a set, thanks
O oldgoat · Premium Member Joined May 25, 2008 · 177 Posts #4 • Aug 24, 2009 imported post On my '82 it is an 8mm Allen key on the left side & a 6mm one on the right side.
T terp · Premium Member Joined Jul 5, 2009 · 50 Posts Discussion Starter • #5 • Aug 24, 2009 imported post thankyou oldgoat,
F fgh · Premium Member Joined Jun 6, 2005 · 1,046 Posts #6 • Aug 24, 2009 imported post On my '83 its a 6 or 8 mm allen on the left and a 12mm hes on the right???
Hatchetman · Guru Joined Jun 18, 2007 · 3,074 Posts #7 • Aug 24, 2009 imported post & you dont have to pull your bags off, Just lift up the weather stripping to find a slot that allows you to go strait in!
T terp · Premium Member Joined Jul 5, 2009 · 50 Posts Discussion Starter • #8 • Aug 24, 2009 imported post thanks I'll get a set of these especially 6,8,and 12. thanks. terp
Bagmaster · Registered Joined May 30, 2008 · 10,509 Posts #9 • Aug 24, 2009 imported post oldgoat wrote: On my '82 it is an 8mm Allen key on the left side & a 6mm one on the right side. Click to expand... Same on my 82.
