I'm trying to make some repairs after a collision. My lower cowl got cracked on impact with a curb. This is the part that's held on with 3 Philips head screws. The service manual calls it the "under cover."
The center screw won't come out. It's in a position where you can't easily apply the needed force to get it out. I took it to a local bike mechanic for advice. He tried too and unfortunately rounded the Philips screw to the point it is useless. The screw is also recessed, so squaring it off, etc. would be hard, and you still couldn't get a wrench on it.
Since it's broken anyway, I am thinking of breaking the cowl part to bits so I can get to the screw and remove it with brute force. I'm a little worried about busting the plastic away then still not being able to get the screw out. Any other ideas?
p.s. That is a lousy spot to use a screw. It gets a lot of road spray, and can't be worked on from head-on. I plan to replace it with a hex head bolt. You might think about doing that proactively if yours is still removable.
Thanks.
Eric
Thanks.
Eric
