drill 1/2 in hole thru side walls. install a piece of all thread with nuts and large washers thru tire. tighten, an air impact works makes it easy. this should collapse the tire and tire irons can get it off. regards walkabout :)
Vintage Rider
That works if you don't plan on using the tire again. Back before I acquired a bead breaker, I always just layed the tire/wheel on a heavy piece of carpet, sprayed some WD-40 around the bead, then stood on the tire sidewalls and jumped up and down. My 240 pounds always got it loose. A couple of times I used a homemade bead breaker, made out of a couple of 2 foot pieces of 2x4. I drilled a hole in each piece, just past the tire tread, then used the bolt, nut, and washers to squeeze them together, with the tire between them. Either way saves the tire. I just recently removed a good tire from a bad wheel, and installed it on another wheel.
