Banned
How do you remove the chrome trim just below the windsheild on a 86 1200 sei aspencade faring.i need to replace the windsheild.and how do you remove the windsheild?
You have to remove both mirrors, then beneath the mirror mounts are two screws on each side that hold the aluminum trim on. In addition there is a clip fastener just above the headlight that you have to pop up on the trim to get it to release.
2008 Goldwing 1800
Randy has it right. Remove both mirrors. Then a screw on each side of the windshield. Mine slides to the right on a bracket and then lifts up. But I have a 98. Might be a little bit different.
Guys?????????
On the GL12, to remove the windshield:
Remove the upper mirror bolts.
Slightly loosen the lower mirror bolts.
Protect the headlight and use a flat screwdriver to pop the windshield garnish up, then remove it.
Remove the 4 screwsthat holdthe windshield to the fairing. (note how the pieces are arrangedto easere-assembly)
