Last summer I replaced the timing belts--simply made sure nothing moved from the position it was in when the old belts were removed and had no problems. (Didn't check TDC, or rotate motor by hand 2x with spark plugs removed, etc...:doh
. However, ever since then I have had a distinct high pitched whine from the front of the motor--my guess is the tensioners are squealing. Is it possible to remove the tensioners from an 1100 and replace them without removing the belts? Just trying to idiot proof the process as much as possible.
