I just took off my fairing and want to run without it. Need to know what if any replacement lights I can get.
Several options, you can haunt eBay for a headlight and mounting ears, or you can google for a 'universal motorcycle headlight and mounting brackets". The latter is probably the less expensive. Look for a 7" headlight and mounting brackets. You can also find turn signals that will fit the mounting brackets for reasonable cost.
Check out this site for headlamps at a reasonable price: Parts N More
I too took the fairing etc off my 77. I found a real good orginal headlight assembly on ebay that worked out to be cheaper than an aftermarket headlight & bucket.
The turn signal stems are ususally the hard part to find.
I looked for a long time and then went a different route but I have since seen that a fellow in Arizona sells them. Might be Crescent Moon Cycle.
Banned
Yea, I would try Cresecent Moon, He should have something around, if not might beable to find you some. I just have the bucket, no ring or anything.
