Hello all,
Which front disc isconnected with the rear brake? Also do I have to do the bleed on the front first because it is farther from the reservoir?
Discussion Starter #2
Got my answer left front disc with rear brake
hello,
sitting on the bike, the right front, is linked to the rear.
I took that out of the Haynes Manual Have not look at it myself so it may be a misprint.
:waving:Both the '83 GL1100 and the GL1200's linked brakes are: R/H front and rear are linked. I believe that changed with the GL1500 as the L/H front and rear are linked.
That's the way both my 1100 and 1200 were linked. The 1500 is left side linked.
You guys are right the manual is wrong. I opened the right front bleeder port and it lost fluid with the rear brake pedal. Thanks for the help.
