I have had a problem with the forks on my 1981 GoldWing GL1100. They leak badly. I had new seals put in but they still will not hold oil or air.
:shakehead:
I have been trying to buy a replacement set and have gotten conflicting information. I was told originally that the forks from a GL1000 would fit just fine. That has not turned out to be true. The GL1000 forks are a smaller diameter and have different fittings.
:doh:
I have sold the set of 1000 forks I bought ande now have a set that are supposed to be from a 1983 GL1100 that came complete with the triple tree, fork brace and top clamps and hoses. The only thing is they are longer than the ones that came off the bike. I'm not even sure it had 1100 forks to begin with now. These new forks have a label on them that says TRAC on the bottom outside leg of the fork.
:headbanger:
My question is how do I know that I have the right forks? AND, if these are in fact from a 1983 GL1100 will they fit my '81?
The 83 gl1100 has a trac fork anti dive system on it. They should plug and play with a 81. I have a 81 and put a 83 forks on her the tubes were from a 82 but they matched perfect with the 81 forks. How much of a diff in size is there? I have been running with 83 forks on my 81 for 20+yrsworks fine.
You may need to used the 83 calipers as well. Not sure if the 81 caliper will mount on 83 forks. The 83 caliper are better anyways with duel pistons vs single.
Can't be 6in diff no way! They should measure around 31" top to bottom ( top cap to bottom bolts caps) under normal load sitting on kickstand. That's the way my measure now.
Because of all the differences in the front brakes on the GL1100, I'd say the only safe bet is '80 or '81 forks.
To put '83 forks on, you'll need a lot more stuff for the brakes, like calipers. No guarantee that the '83 forks and '83 calipers will line up with the '81 brake discs either. '83 and '81 fenders are shaped differently as well.
I used my 81 fender on the 83 front forks and front tire. Just needed to trim the inner fender bracket tabs off because the 83 tire is a wider 120/90/ instead of 81 stock 110/90 .other than that the fender fits fine.
You will definitely have to use the entire 83 frontend ,wheels calipers rotors everything except the master ,( Triple trees are the same, leave them alone! find an 82 model master to use and you need the front hoses off any year 1100 BUT the 83 model , they have a linked system with a smaller master for the front as it only acctuates the front left caliper. the pedal acctuates the rear and the right front.
This set up will give you the best frontend and brakes for a gl1100. without a whole lot of expense and headache. I have an 80 model with this setup, doesn't run anymore but I plan to use this as soon as I can take her down a few days , hopefully this summer I can do the swap!
Haven't been able to find the other parts so I will be getting rid of the 83 forks and looking for some 80-81 forks. I had my current forks rebuilt once and the left one still leaks and neither will hold air.
Thanks for all the info, it has been very helpful.
