1 - 9 of 9 Posts
I have decided it is time to replace my brake lines all around. Going with ss lines and I am wondering if this is a real big chore or something fairly easy (not counting the brake bleeding which I understand can be something of a pita). How much disassembly of the bike is required? Thanks for the help. Randy
I haven't actually replced the lines but bleeding to change the fluid isn't much of a problem. Gravity pretty much does it for you on a 77.
on the 1200. replacing the lines isn't a problem but the bleeding is a pita.... your rear master works one of the front brakes (it is a "linked" system).... it is a pita to get the air out of the line that goes over the hump of the engine to the front.... speed bleeders with a mighty vac can help.... so can using a syringe to actually enject fluid from the front to the rear master
Less than 2 hours too do front brake, had vacuum bleeder. Good upgrade, made a big difference in performance.
Thanks for the replys, a little apprehensive but it is something I have been thinking about for awhile so I need to get off my dead b---- and get it done.
Drop a PM to goldwinger1984 or drop in at gl1200goldwings.com and talk to Vic. This is one of his specialties.
I'm planning on doing mine this winter. I won't be missing any riding time so I can take it slow. where's the best place to get them?
1 - 9 of 9 Posts
