Hi All, I am going to be replacing my rear tire in the next few days, due to puncture
, while I'm there I need to replace myfinal drive seal as it has been dribbling for some time now
I did some research here and found some good info but couldn'd find anywhere saying if there is more than the one drive seal, part # 91261-ME9-005
the oil is always dripping off the bottom of the drive housing just below the fill plug
and will drip onto the wheel
when I look at pictures of the final drive it looks like there might be 2 seals and maybe a gasket or o-ring on the large outer housing
I'm working on a 86 Aspy
I plane to clean and put fresh moly on the splines and grease the u-joint while Im there as well
So are there more seals/o-rings in addition to the above stated seal
