The Goldwing is a nice bike, but not perfect, Honda should have solved this design problem before putting the bike into production. I think I would live without the neutral light before I went to that kind of trouble.
My sister had a late '80s Honda Accord, and the water pump went out. Under "replace water pump" in the manual, step 1 was "remove engine". And this was a FWD car, you couldn't just lift the engine out the top like a RWD car. The engine, transaxle, and front subframe had to be dropped out the bottom, which required a hydraulic lift and a special holding fixture. I chose to cut a large hole in the inner fender with an angle grinder instead, and suggested that she get rid of that junk ASAP. Honda is not known for building things that are easy to work on, nor are they known for continuing to provide parts for what they build. They build quality stuff, but when it breaks, watch out!!
