1 - 20 of 55 Posts
· Registered
Tire Vehicle Automotive tire Bicycle tire Hood
I'm at my wits end. I picked up a 1987 Gl1200 aspy for $600. Been off the road for 6+ years. Fixed the starting issue, Fixed the clutch, old owner had the electric fuel pump wired directly to a toggle switch, which I feel is a big no-no. So I pulled all his crappy wiring off and am attempting to wire the fuel pump to pulse with the ignition coil. CAN SOMEONE PLEASE TELL ME WHICH WIRE FIRES HOT
Tire Wheel Fuel tank Automotive fuel system Motorcycle
Automotive tire Hood Motor vehicle Automotive fuel system Automotive exterior
TO MAKE THE PUMP PULSE WITH THE COIL? please for the love of God, I have all the schematics, tried half the damn wires coming in and out of the ignition module. Still can't get it.
Rectangle Schematic Font Parallel Engineering
Font Slope Parallel Rectangle Schematic
Rectangle Slope Parallel Font Pattern
· Administrator
What you are after won't work with that relay. Don't know what you mean by "fires hot", the wires to the spark plugs fire hot. The original fuel pump relay used the yellow wire to the right coil to energize the relay, it is a pulsed ground.
· Registered
Thank you Dave! Is there another way guys usually wire a pulse fuel pump to make it timed to the engine speed so the bike can stay running? Or am I going to have to restore the original wiring?
· Administrator
There is no such thing. The pump gets constant power when the engine is running, the pulse is determined by how much fuel is being used.
· Administrator
1987 GL1200 Interstate
Welcome to the forum.
The schematic you are looking at is for an '84. You should be looking at one for the .87 Aspy. There are differences.
Also, that looks like an aftermarket pump. May be wired differently than an OEM.
Also...and this is a big one...the '87 fuel system is one year only. NONE of the parts are interchangeable with any other year. Tank, petcock, hoses, filter, pump and carbs, the whole system, different.
· Registered
I see what you mean now about the relay I'm using, definitely not going to work with this application, guess I'm going to have to restore the original fuel relay to working order.... at idle if I leave the fuel pump switched on I have gas pouring from the overflow vents under the carbs, I was holing there was a way to speed up and slow down the pump dependant on rpm, however not so sure how that's possible if I can't use the coil.
...oh God no... sigh
· Registered
Discussion Starter · #8 ·
Did not know there would be major differences, thanks for letting me know... further down I go!
· Administrator
No it's not possible. As mentioned above, you have a carb or fuel pressure problem.
· Registered
i would get a good OEM wiring harness and relays. you will need that harness again and again. was it cut to accomodate the nekkid aboration? is it burned? tell us what happened to the original harness and you will save a ton of $$$$ , blood, stress, time, etc:
looks like you have a nice,clean slate to start your restoration, most of us only wish ours had started with what u have.
there is a reason it was $600. P.O. screwed it up, gave up, put it up for sale. you can fix it, once you get it all back assembled, and can ride it, you will forget all the issuse, and just enjoy the ride!
it is obvious the charging system has fried. may as well repair the bad repair before sinking too much into it. if you are not certain it will run, shift, charge, be safe, i wouldnt spend another dime until i WAS sure.!
· Registered
Discussion Starter · #12 ·
Thank you so much for the help fellas, so glad there are awesome forums like this to help us new guys out! I'm gonna run down to the auto parts store and see if I can find a 1psi fuel pressure regulator.... maybe 1psi feeding 4 carbs won't cause an overflow? Fingers crossed
· Registered
yep, you can experiment (the expensive way out) all you want, but at the end of the bank account, you will wish you had quit trying to outsmart honda and fixed it right for cheaper. a regulator will restrict flow, and will also make pressure look like a sine wave. fluctuating all over the place. your local auto parts will sell you more junk, over and over. listen to all above. just go with OEM.............if that aint right, you just keep guessing what to spend money on next.
1 - 20 of 55 Posts
