I have always wanted a Honda GoldWing, I happen to find one for $200, been sitting out under a walnut tree for 12 years with the fuel still on. I've changed the oil & filter, gas tank was empty and clean.
I've replaced so much stuff on her, carbs/ levers/fuel pump/plugs/excetra. Still no start. Need help.....
Is it getting spark? Does it have compression? Is it getting fuel to the carbs?
I'm checking out why it still turns over with the kill switch turned to off position?
My v-star don't do that. Is that suppose to happen?
Yes it will crank with the kill switch off. Honda didn't fix that defect until the mid 90s.
