I am replacing the passenger floor boards on my 95 Aspencade with adjustable floor boards from an SE. I was hoping someone could send me a picture of how and where the passenger control cable connects. If no picture, perhaps a good explanation. Thanks.
Just went outside to look since mine is off the bike. Anyway if you turn the switch pocket over there should be 2 plastic boss inside on the bottom. That is where the 2 screws for the control screw into. You will have to cut a slot on the front side so you can connect the handle to the metal arm. Hope that helps
Never mind, I see you got it covered
