No, you do not need to engage the clutch to take it out of reverse, errr at least on mine I did not have to.
:cheesygrin: Good luck!
why would you need to replace anything if your lever is loose you first need to slid off the rubber cover on the handle and check that the allen bolt is tight, In order to engage reverse you pull the lever out away from the bike then pull it to the upright position and push it back in towards the bike in order to lock the lever, In order to do this the bike has to be in neutral no clutch lever needs to be touched then press and hold the start button its as simple as that,newday777 Thank you very much..what should I lube it with? Just regular grease? Sorry I'm kind of a rookie when it comes to stuff like this...I'm just wondering..would I need a new pin as well as a new rubber sleeve?
Thank you
