I backed my 2004 Wing (ABS) into garage. Forgot to push Reverse button off. Shut down unit. Lifted it onto center stand. Later pushed off center stand. Evidently impact locked gear solid. Reverse light was on when I turned key switch to on. Switchedreverse off. It did not release the locked wheel. Reverse switch will not come back on if I push it in. No green neutral light. Can't start it. Red indicator lights come on for oil, ABS, etc., but no gold for reverse or green for neutral. Can't shift gears. Tried rocking it hard backwards (a lot). No success. Have downloaded service manual. Trying to find exact location of the cable that holds it in. Understand there is a nut that can be turned to release it.Need some more cluesor what perhaps to specificallylook for or in manual. Checked #23 fuse. Replaced with spare. Apreciate any help.Thanks.
