Has anybody encountered a no reverse situation on a 98 asplencade.When i put my bike in reverse the light on the dash comes on.I then press the starter button and nothing happens,not even a click.Please help if you can
I would first check the fuses.
Kit
Senior Guru
hi dreamcather can you fill in your location as there may be some one near to help you.
Just go to the menu on the right, click on My Account and then click on Profile. If you scroll down a bit you will see where to enter stuff.
Welcome to the forum.
Token Canuk
Have you tried holding back on the rev handle while using the starter button, sometimes they need a little help ?
have you checked your battery. I understand ( and i may be wrong) that if the nattery is low, it will not reverse.
