I have had my 1997 GL1500SE converted to a CSC trike it originally had a central light cluster on the rear including a reversing light.
I wish to fit a reversing light to my trike and am having difficulty locating the wiring to feed the reversing light, does anyone know the colour code and where I might pick up the wiring in the existing wiring loom.
Thanks in advance.
Terry
Not stock.
You may have to trace it from the rev. switch which would feed the dash light as well
You would need to remove the rev. handle & the cover over it.
The switch is next to the handle.
Pwhoever
On the left side under the trunk towards the front is a small square aluminum block that IIRC is the starter relay regulator????. It has red connectors on it. That is where I had to connect my Showchrome aftermarket running/brake/reverse light.I'm guessing that is the same light assembly that you are talking about and was modeled after the Simpro one. If you remove the lower cover off the trunk, you should be able to see those connectors. I don't have the wiring diagram handy that showed which wire is what. If I can find it, I will try to post it later.
Take a look at post #7 in THIS THREAD
