I did see that he was talkin about bypassing "all" safety switches... but there are cases where bypass is not possible to retain the reverse function, or to have the bike shut-off, etc. (example, bypassing the reverse switch would disable either reverse or the starter-crank; similar with the Reverse lever switch...)
The frame references were included sinc identifying wire locations in a 3-dimentional harness is a bit tough wihout some reference. Having moved engines between platfoms myself, there's always some recollection of "where was that" on the.donor bike.
Guess I just suck at this then, eh?
