I bought some of this stuff because I live and ride on 4 miles of gravel and have had 2 flats this year already. It is different than other tire sealants out there. I will let everyone know how I like it and if it does what it says. Here I have attached the info. Does anyone have any experence with this stuff.The guy at the Motorcycle supply store swears by it and has sold several cases for street bikes.
Randy
Ride On Tire Protection System
Description:
STOP FLAT TIRES BEFORE THEY STOP YOU
Ride-On Tire Protection System (“Ride-On TPS”) is a revolutionary line of tire sealants formulated to prevent flats caused by punctures from nails, thorns, screws and other debris.
Ride-On TPS tire sealants extend tire life by hydrodynamically balancing tire/wheel assemblies, lowering tire operating temperatures and helping tires maintain their set-point pressures.
Vehicles with Ride-On TPS benefit from better handling, better fuel economy, longer lasting tires and a safer ride.
Ride-On TPS tire sealants also help to reduce the expense and aggravation of flat tires and premature tire failures.
Ride-On TPS comes in several formulations for use in both high-speed, on-road as well as slow-moving, off-road applications
For more info see http://www.ride-on.com
Randy
Description:
