1 - 20 of 22 Posts
I am a new member and this is my first post.
I purcahsed this great bike from a new friend and removed the rear wheel following "How to remove a rear wheel" to get the valve stem replaced. Prior to removal, the trunk and saddlebags locked and unlocked perfectly. After reinstalling everything,( or so I thought),the right saddlebag won't lock. Did I miss a step or is there a little part that needs connecting?
WELCOME:waving::waving::waving:
Welcome to the forum.
Most times its can't open a bag. When you say can't lock do you mean can't close them shut?
Did you remove both of the bags?
Did you save the post you read on the how to? If you did then copy and paste the address in a reply to this post so we can look it over to see which way you did it.
Patience, an answer will come.
Gregarious Greeter
[align=center]
[/align]
[align=center]Welcome kbfisherman[/align]
Welcome, WelcomeTo Steve Saunders Goldwing Forum.If you have any questions no matter how trivial they may seem this forum is the place to ask them. What I have noticed is that some of the people here were :15red:'sin their previous lives and can answer any question you have. Theforums that I get the most from are::
Goldwing Technical Forum
General Motorcycle Discussion Forum
These have the best info aboutGoldwing’s and are where you ask questions and can get help..
For Sale/Wanted ForumGood stuff for Sale or if you have old parts sitting around the garage you would like to get rid of....
:18red::15red::12red::11red:
And when all you need is a good laugh to start your day try the:: Fun Forum After that it’s up to you which of the others you will like the best all I can do is suggest.
Again Welcome to the Forum...
Oh and did I mention everyone here loves pictures.. Show us some of yours... Even if it’s not a Goldwing just a pretty view
Token Canuk
Welcome kbfisherman, I've had quite a few OPP friends who did time in Kakabeka, & we have been through a couple of times on our tours. There is a little clip to reconnect to the bar inside the bags and I have had the catch/latch on the door get moved while the doors have been open, loosen them with a phillips screw driver & re-adjust them might help.
:waving:
Honda Guru
You might have to pull the saddlebag back off… only slightly though.
There's the cable that runs from the 'release levers' under the rear trunk directly to the saddlebag.
The cable to the right trunk has pulled out from it's hole in the saddlebag. It's a push fit and can pop out easily. It'll pop back in just as easily but it's hung up right now. That pulls the release bar and keeps the lid from shutting…. just like your problem now.
Oh yeah…. Welcome!!!!
Welcome from Oklahoma :waving: Enjoy the wing :cheesygrin:
I had the same problem on my right saddle bag and I found that the cable was not quite routed correctly under the rear storage. I removed the cover under the rear storage trunk and rerouted the cable and it worked as it should. Now every time I remove the saddle bag I have to make sure the cable to that bag is routed in more of a straight run to the bag or it won`t latch. That was my fix, yours may be different though. :baffled:
Busdriver
Did you replace the white plastic clip that attaches to the long release bar inside the bag?
If so did you put it on the right way?
Discussion Starter #18
Thanks for the hints. The clip appears to be on ok. The problem is in the key lock. when the key is used saddlebags should lock. The left one does but the right won't lock. The trunk locks.
1 - 20 of 22 Posts
