RM-1100 RM1100 Radio Problem
486 Views 1 Reply 2 Participants Last post by  tricky
Hi All
I've been having problems with my RM-1100 radio fitted to my GL1200
I've found that a wire has snapped off the 24 way large blue external Socket.
Has anybody found a way of removing a pin from these beasts so that I can re-solder it back on? There does not appear to be anybody in England that repairs these radios.
Thanks in Advance
Ade
1 - 2 of 2 Posts
Not sure about the socket your talking about but most electrical plug pins have have a small strip that prevents the pin from falling out. I have had success by using a small needle and prying this strip inwards then you can push the pin back out from the rear of the plug.
Take a bright light and look down the plug usually you can see where you need to pry.
BOL :)
1 - 2 of 2 Posts
