While knocking the rocker arm shaft out of the camshaft housing I accidentally hit one of the side plugs. :whip: It got loosen so I pulled it out easily with screwdriver. Now I am not sure which would be the best way to re-fix it? Some "Loctite" glue maybe?
I wouldn't like it fallen out later....camshaft would loose the lubrication, plug itself could crush something:shock: ....no thanks!
So, loctite or some other way? Thanks! :waving:
