Hi all from Wigan UK.
I really enjoy riding my goldwing but am an absolute technical novice so I am asking for advice on removing the rocker valve covers for the purpose of cleaning them. I have read lots on this site about how to go about it but I still have a question - do I need to drain any engine oil first or can I just set to and remove the covers?
Thanks in advance for all your replies.
By the way it is a 1985 GL1200 Aspencade
It's not very fun. I don't drain any oil before I pull mine, but you will lose a little, so be prepared to catch it and check/refill oil level when done. To pull them you'll need to pull the lower fairings and engine guards, which I have not been able to do without dropping the exhaust a little. Once all that is out of the way just pull the 4 allen bolts and pop it off. I also recomend doing the gaskets for the base of the covers and the bolts while you're at it, they usually don't like to seal twice.
Thanks for the prompt reply and the advice. That has put my mind at rest. Now have to wait for a dry day to do it as I don't have a garage and the covered shelter at the side of the house where she is parked up has limited access for working on the bike.
thanks again
Ya, you will lose a slight amount. Just put a rag down first.
CAUTION:
Be very very careful when putting the bolts back in. Although the bolt has a large head, the shaft of it is very thin as you will see. If you overtighten, you WILL snap them off. I did that on 2 of them on my 86 Aspencade years ago.
Good catch, I forgot to mention that, you might want to look it up but I think it's like 9 lbs/ft is all they take.
