1 - 3 of 3 Posts
Candy Moose Wing wrote:
Does any one know if a 81 GL1100 has 18mm front rotor and how do you mesure them.
Ron
What are you measuring 18mm? That's about 3/4"
What you're mainly concerned with is diameter, thickness and offset.
The only spec I can find is the thickness, 4.8 to 5.2 mm standard and 4mm minimum. Don't have a clue as to what 18mm could be refering to.
1 - 3 of 3 Posts
