1 - 9 of 9 Posts
Bike runs rough , starts right up, idles smooth but when acceleratingfrom stand stillis very rough. After picking up speed bike seems to run fine. Has good power at higher speeds. Recently had carbs syncronization, points adjusted and timing set, had carbs rebuilt about 1 year ago. Any help would be appreciated.:?
Could be a bad plug cap or spark plug. If the caps are original or old replace them and even a new spark plug can be bad.
The GL1000 had a stumble of idle that can be fixed by putting a washer under the head of the jet needle. Will it start without the choke? How do the plugs look?
Steve
The early 1000's benefitted from shimming the needles, but I've never encountered a problem on the '78 and later. I'm more prone to agree with Dave. Sounds more like an ignition/spark problem. But since we can drive it........
I've shimmed the needles on a 78 and it helped . but if it starts without the choke when it's cold, or the plugs are black, its likely running rich.
Steve
Sorry Steve. I didn't mean to suggest that shimming the needles wouldn't help a poorly running bike. I was saying it wasn't an inherent flaw with the '78 that required shimming if the rest of the carb circuits were good.
But I don't see anything in his post that suggests this bike starts without a choke, or runs rich. Did I miss something?
Thanks for the replies.I have to choke the bike when initially starting,once it is running I can shut the choke down and it will idle but when I give it throttle it runs rough on acceleration until I pickup speed.
He said it starts right up so I was just asking questions. Troubleshooting is less of a guess the more info you have. Some times you just have to solve for the symptom because nothing else works
Steve
vacum advance? do those carbs have slides?
1 - 9 of 9 Posts
