1 - 3 of 3 Posts
I just got to ridding and now problems with how Lucille is running. I have a poor idle, it even stalls; motor is choppy even when applying throttle and won't keep a charge on battery (battery 1 year old). Can someone tell me what is going on?
Sounds like to me that your charging system has failed. Someone with more experience with the 1100 will be along to give you some good info on testing the charging system or other areas to check. I have experience similar symptoms on bikes with failing charging systems.
There are probably thousands of posts on the charging system. Check the A-Z post index. If it still does not run right with a charged battery start with the simple, plugs and filters and seafoam.
1 - 3 of 3 Posts
