I am sure this is somewhere in Steve's pages - but can't find them. Is there a chart that tells you, for example,
that at 3000 rpm in second gear your speed should be X.
Just curious if any of you have ever wondered about this and found a source?
:baffled:
Mike
There is going to be differences due to tire size. Even differences between a new tire and a wore out one. And every year won't be the same.
Raymond
:baffled:
Mike
I don't know, I have a 3000 on my tach but no X on the speedometer!:cheeky1:
LOL - just thought I'd ask :goofygrin:
Mike
Senior Guru
Mike, all you have to do is to get the gear ratios from your bike specs, factor in the primary and secondary reductions and put all these numbers into a calculator and you'll come up with the RPM's you're looking for.
Trans. Primary reduction 1.708
Trans. Secondary reduction 0.825
Gear ratio of 1st 2.500
Gear ratio of 2nd 1.708
Gear ratio of 3rd 1.333
Gear ratio of 4th 1.097
Gear ratio of 5th 0.939
Gear ratio of Final Drive 3.400
The above numbers are for a 1975 GL1000.
Once you determine how many miles you wantyourtires rotates in one hour (MPH)you can then factor engine RPM by using the ratios for your particular bike to get actual RPM's of the engine in each different gear ratio.
With a 1/1 gear ratio if a tire had a circumference of one mile and it rotated once per hour the engine would be turning over at one RPM.
The primary and secondary reduction in the above example just about makes the engine turn over attwo and a half times the speed of the rear wheels and the final drive ratio makes the engine run 3.4 times the speed of the rear wheel.
Now all you have to do is factor in the other gear ratios you chooseandselect road speed through tire circumference and you will find engine RPM for each selected gear and final drive ratio.
Vic
On my 83 :11grey:at 3000 RPM;
1st 18mph
2nd 28mph
3rd 38mph
4th 47mph
Didn't check OD at 3000 but at 3700 it's 70mph. I try to keep it in mind because the speedo was repaired just before I bought it. I guess that after the 17000 miles I put on it I can stop worrying though.:waving:
