The GL1100 I'm working on has a new problem. I found a short in the running lights wiring that was blowing the fuses. I have fixed the short and when I put the key in the "parking" spot on the ignition switch, I get only the tail light. (no other lights come on)
When I start the bike I only get the headlight. No running lights, no gauge lights. Turn signals work, brake lights work.
After reading the wiring schematic, the only placeI can see a possible problem would be in the ignition switch itself.
Any ideas on where else I should look?
