Running Light Question GL1100
476 Views 5 Replies 4 Participants Last post by  dannyeod
Did you know the llittle added runnning lights run 3.4 Volts Each? I have 16 on my 83 Aspy, and that is voltage? I have a switch for turning them off during the daytime.
Nightrider1
3.4 volts? dont you mean watts?
then they all drain 54.4 watts, the same as if you had another headlamp. the volts is the unit of electrical potential our bikes run on 12 volts. the watts is the unit of power.
you may want to switch to leds ;)
And they require about 4.53 amps of current to illuminate them. Amperage is the strength of electrical current.
54.4 watts divided by 12 volts equals 4.53 amperes.
http://www.allaboutcircuits.com/vol_1/chpt_2/1.html
This should help you understand ohm's law.
Why not just make it simple...........
The bulb (or other accessory) plus wiring is the resistance.
Then calculate accordingly:
Conversion of Volts/Amps/Watts
Converting Watts to Amps
The conversion of Watts to Amps is governed by the equation Amps = Watts/Volts
For example 12 watts/12 volts = 1 amp
Converting Volts to Amps at fixed wattage
The conversion of Volts to Amps is governed by the equations Amps = Watts/Volts
For example 120 watts/110 volts = 1.09 amps
Converting Amps to Watts
The conversion of Amps to Watts is governed by the equation Watts = Amps x Volts
For example 1 amp * 110 volts = 110 watts
Converting Volts to Watts
The conversion of Volts to Watts is governed by the equation Watts = Amps x Volts
For example 1.5 amps * 12 volts = 18 watts
Converting Watts to Volts
The conversion of Watts to Volts is governed by the equation Volts = Watts/Amps
For example 100 watts/10 amps = 10 volts
Converting Amps to Volts at fixed wattage
The conversion of Amps to Volts is governed by the equation Volts = Watts/Amps
For Example, 48 watts / 12 Amps = 4 Volts
Ohm's law, I understand it but its difficult for me to explain. Good job DBohrer.
:action:
