1 - 13 of 13 Posts
· Registered
I had problem with compression on my GW 1200 -84. Cylinder 1,2,3 had 11,5 bar no 4 -9, 8 bar. I dismantled cylinder tob and lapet valve and valvseat. After mounting i have bad running. Timing belt are corekt. The engine are misfiring?? It runs bad on idling. I have don reasembly according too Clymet book without sumerg hydraulic lifters in keroosin/oil??
· Registered
The lifters should pump up on their own, it just might take a while. Are you having a lot of valve train noise?
If it ran fine before you took it apart, and now it doesn't, obviously my first thought is you made some mistake. Go over everything you did and start at the basics.
· Registered
try compression check with the carb slides and and butterflies open. you may just find BOTH problems. a vacuum test will give clues too, but since you have limited data, just pull the slides and hold the throttle fully open and run a compressio tes again. make sure battery is fully charged between each cylinder test.
· Administrator
No need to pull the slides.
· Registered
Discussion Starter · #12 ·
Hi
There are not any valve train noise.
What are the consequences with to litle ore to many shims on the hydraulic lifters??? I have checked the measurement and all lifters are under minimum.
1 - 13 of 13 Posts
