How does the carb-sync relate to rich running carbs or does it? Mine all check out within 1/2 in Hg of each other, but my bike still runs rich and gets less than 30 mpg. I've only had the bike a few weeks, so I'm just getting around to performance. I've changed the plugs, air filter, synched carbs (no adj needed). Plugs are whitish gray in the middle and dry carbon on the outer edges all consistent.
Also, my bike originally came from Northern North America. The previous owner moved to Florida and I bought it from him. I'm thinking that the vastlydifferent climates and humidity is causing my rich condition. I doubt the previous owner had it re-tuned when he moved here.
Is there a procedure for mixture adjustment, or what is the nominal setting? Certain number of turns?
