mag wrote:
Now it's just a matter of slowly wiggling the tank back and forth and pulling wires and hoses out of the way as the tank comes out the back.
mag wrote:
Okay... for a GL1000 - remove the rear wheel, rear brake master-cylinder and caliper (they can be removed as one unit without disconnecting the hose), remove the outer and inner fenders, unbolt and move the battery box out of the way, unbolt the fake tank (4 bolts at the bottom) and move it up enough to clear the fuel-filler neck, disconnect the tank sender (top of tank), remove the petcock, and remove the tank mounting bolt. Now the tank should be loose. And there is no need to remove the final drive.Do you have to even remove the rear wheel? Clymer says just the rear fender to get the tank out. Can you get the fender(s)/tank out without removing the wheel?/forums/images/emoticons/emoticonsxtra/baffled.gif
