I have been told that there is rust in my gas tank and the rust is getting into my carbs. The technician told me there is a way to treat the tank by coating it with 3 coats of an epoxy type material. He says the removal of the tank is the most difficult task. He also mentioned the breathing tubes could be damaged if I was not careful. A new tank is not an option as they are not available for a 1980 GL1100. Actually the bike runs ok but under load in the higher gears it sputters a bit . It is much better since I put carb cleaner in a couple of tanks of fuel. Does anybody have any input?
