The 05 1800 I have is built to Australian specs and I would like to have the lights in the saddlebags working(they are not required in Australia). I see on Ebay someone is parting out an 02 1800 and is sellingboth saddlebag lights. My questions are:-
Will these lights from the 02 model fit an 05 model?
Do the coloured lenses seperate from the black rear part of the lights as I would prefer tokeep the new lenses on my bike?
Regards to all.
Yes they will fit fine, the back part is not removable. Why not just melt outythe holes for the bulbholders in your own lights? The outline of the hole is easily seen because it is stamped into the plastic. That way you keep your new lights instead of fitting old ones.
Hi cbhon, the UK and European models are the same. Most of the UK guys just drill and file out the bulb holes, like Ambrose said they are already marked out for it.
Other side of the pond
I can confirm that, its cheaper to cut or melt out the holes than to buy new lights. If you really want to buy new ones, it's cheaper again to buy a whole rear set of clear aftermarket lenses than to just buy the lower Honda set.
