I mounted my SkyFi docking station, FM wireless modulator, an additional power outlet in the "hump" of the travel trunk. I also have a place in there under the rear of the rack area for the antenna, I set the station before I get on as I know what I'm gonna listen to .... and it works without interfearance as the FM Modulator is not a foot from the radio antenna.
If I have something on the rack, then I have a hole I pass the antenna thought and simply stick it to the top of the rack or on top of whatever I have on the trunk.
It works so well on the 1500, that I removed my front handle bar mounted setup on the 1200 and remounted it the same, eliminated interfearance. I should add that in both cases, my docking station has a "button" made from aluminumback that is designed to fit a heavy dutyGE Communications mic clipand once snapped in place, no rotation happens. It means I can use these two setups interchangeably or in my older '77 Ford PU or .... any car if needed on a temp basis. My other vehicles have dedicated docking stations with wired modulators .... thanx Ebay.
Radio signals ...if you cut the distance between the transmitter (modulator) and reciever (antenna for AM / FM) by just half, you quadruple signal strength. I shortened it from several feet to under a foot.
