Normally, I have always used Gumout with REGAIN.The REGAIN is the secret ingredient that makes it the best gas additive to cars and bikes. When I use it on my Valk (4 gallon tank) I used it over three tanks. With seafoam, do I put the whole bottle in on the 6 gallon tank on the wing?
Senior Guru
hi dragoon there is a lot of posts on sea foam most guys use half a can on a full tank did you get your cb sorted
Yup, the TX was not comming on. So i wiggled some wires and could get it to come on. So, after some playing, i was able to tie wrap it such that it works fine. I will look at the wires when i get a chance.
Well, I just bought some last week & read the directions...they recommend 1[suP]1[/suP]/[suB]2[/suB] oz. per quart of oil in the crankcase, and 1 oz. per gallon in the gas tank. :action:
Also, I see they have several other products out there, and I almost bought the wrong stuff for my application, as the cans are printed similarly...had I not noticed in time, I would have been adding their auto trans product to my wife's crankcase. :shock::3sum:
:waving:The directions are on the Sea Foam container just follow what it says and you'll be OK.
I don’t have my manuals with me, so where is the oil filler?
Senior Guru
right side remove the battery cover then the carb cover filler and dip stick are just infront
Probationary
I just put Seafoam in my gas tank yesterday. Since it's running fine I put 1oz/gallon [mostly for storage].
If I am cleaning out my fuel system & carbs, I put the entire can in, run it through the same day, refill the gas + change the oil & filters when I get home.
Every Spring, I put about a half can in the 90 day old oil, run it for about 50 miles & change the oil before it gets cold.
About the same routine for my last 5 bikes.
For both my4 wheels I useabout 0.5oz/galof Isopropylalcoholin thegas tankwith every fill up during sub-freezing weather. It's about 5x cheaper than the dry gas products.
02 GL1800 w/Auto Pilot
??? Isopropyl alcohol is mostly water ?
Methanol yes, Isopropyl? I wouldn't.
Guru
isopropyl is used as a treatment in diesel engines for it's water displacing properties.
