:angel2: My natural gear is o/d at around 75 to 80mph. My neutral gear is between 1st and 2nd with a little finesse. Without starting the bike, find neutral by rolling it back and forth. Then turn the key on and see if the light works. If not, check for a burned out bulb, (not buld), or just replace the bulb. If that doesn't work, you need to see if you have any wires loose by doing some tracing. Do you have an repair manual? That should help you trace down the wires.
We are kidding you about spelling, but if you look at the top right corner of the screen in which you wrote your original question, there is a check mark with abc. That's the spell check. You can also download a program called iespell. Check the forum for more info.
Good luck and let us know how you do.
Jerry
