1 - 3 of 3 Posts
i need to know if the SHIFT FORKS & DRUM off a 85 LIMITED EDITION
will work on my 84 goldwing I 1200
and what other parts off a 85 goldwing internal parts off this motor
or are the short blocks the same 84 to 87
both bikes are pretty much the same, the limited edition has fuel injection, some hardware for the cooling system is not the same at the thermostat housing. the stator is bigger so the back cover, the transmission, crankshaft, pistons and other internal parts im sure are the same
Go to one of the retailers that have a microfiche parts look-up like bike bandit or Honda parts direct( if they are back on line) and look up the parts for one and write down the numbers then look at the same parts for the other bike and compare numbers.
1 - 3 of 3 Posts
