What kinda fluid should be run in an 82 Wing Standard. I have heard hydralic fliud but just not sure of it or if there is a specific kind that should be used.
Thsnks for any help on this
I'm not sure if you are asking about the front forks or rear shocks.
Front forks use a fork oil and the weight is usually 10 or 20 weight oil. Just follow manufactures specs. I'm not sure about rear shocks but I would think the same oil would work there as well but they are not easy to refill and it's usually easier/cheaper to just replace them.
Both front forks and rear shocks work on the same principle, just that forks require more periodic maintenance and are easier to rebuild.
In the factory service manual on page 12-7 it saysunderthe headingFront Fork Oil Replacement - "ATF capacity (after draining):
1980-1981 220 cc (7.4 oz)
1982270 cc (9.1 oz)
I just rebuilt my front forks and used ATF. I am just following what the "factory service manual" says to do. Maybe some one can prove it wrong.
Edited:
ATF IS hydraulic oil. It only has a red dye in it for the masses so they can see if their transmission is leaking. Hydraulic oil is a light brown to clear color andcan go with an unnoticeable leakfor a long time. By the time most sheeple would notice the hydraulic leak in their transmission,it would have burned up the automatic tranmission.
I used Mother Honda's Fork oil in mine. It is a 1980 GL1100, and it uses 10 wt. for the front forks. Expensive though. $16.00 plus some odd cents, but plenty to do both. I would not replace them though, just put in fresh fluid after draining it well. The only difficult part is getting the top back on. a little tough, but I have lost 100% feeling in my left hand, and 50% on my right,and I done it barehanded, then torked them down.
Good Luck,
Nightrider1
