I have a 1980 standard 1100 and theres about 10 toggles on this bike
from previous owner... should I wire the taillights to be on all the
time? Headlight has to be on always (law) anyway. Thinking
of just filling in the toggleswitch holes with plastic auto
plugs. maybe leave one for driving lights. How does yours
work?
Senior Guru
All the USA Goldwings have the lights on all the time, headlamp cuts out when you press the starter button to save the battery. As the taillight & running lightsis onlysix 5 watt bulbs it won't draw too much from the battery so it's not really worth putting a switch in for that, unless you have other lights on at the same time. Mind you, when you are working on teh bike with the ignition on it would save the battery running down if you did fit a switch.
Do you just have the stock tail light(s)? If so, I'd wire them to be on all the time. If your tour pack looks like Christmas at night, I'd leave them on a separate switch. They're just an extra draw on your charging system, that's not really doing anything for you in the day time.
He described his bike as a standard. Why would someone put all those toggles? The standard should just have the 2 1157 bulds in the taillight. They should be on when the ignition is on. If those switches don't have a good purpose, remove them and clean up the wiring. Extra switches and wire are trouble waiting to happen.
